[DL510] Printing and Testing Bridges Part 2
Session 10: “Reflection and Optimization: Learning from Results”
In this session, Grade 5 students will reflect on the performance of their bridges based on the testing results from Session 9. They will analyze why certain designs were stronger and discuss improvements that could enhance durability while using material efficiently. The teacher will introduce the concept of optimization, encouraging students to adjust their designs for better strength and efficiency. Students will share their insights and develop plans for future design improvements.
  • Reflect on Bridge Performance: Analyze test results to understand which design elements contributed to the strength of their bridges.
  • Identify Areas for Improvement: Determine which parts of their bridge designs could be optimized for better durability.
  • Understand Optimization Concepts: Learn how to enhance structural strength while minimizing material use by adjusting infill, adding ribs/trusses, and incorporating fillets/chamfers.
  • Collaborate and Share Insights: Engage in discussions with peers to share feedback and ideas for future designs.
  • Plan Future Improvements: Develop a strategy for refining their bridge designs in future sessions.
  • Data Sheets and Graphs: Examples of recorded test data and simple graphs showing bridge performance.
  • Before-and-After Comparisons: Images or diagrams of bridge designs with noted improvements (e.g., with and without ribs).
  • Step-by-Step Guides: Screenshots or slides illustrating optimization techniques in TinkerCad.
  • Infographics: Visual aids summarizing key optimization concepts like optimal infill density, adding ribs, and using fillets/chamfers.
    • For accessing TinkerCad and digital guides.
    • For displaying test data, diagrams, and optimization examples.
    • For students to record observations and ideas.
  • Printed Data Sheets:
    • Collected from Session 9 to review bridge performance.
    • Additional adults to facilitate discussions and provide technical support.
    • “Good morning, Grade 5! Today, we’ll reflect on the results of our bridge tests and learn how to make our designs even stronger.”
  • Recap Session 9:
    • “Last time, you printed and tested your bridges, recording how much weight they could hold. Let’s review some of the key observations and data from those tests.”
  • Present the Session Overview:
    • “We will discuss what worked well in your designs, what could be improved, and how to optimize your bridges for strength and material efficiency.”
2. Analyzing Test Results (15 minutes)
  • Review Data Sheets:
    • “Look at the data sheets you filled out during testing. What was the maximum weight your bridge held? Write down your observations.”
  • Group Discussion:
    • “Discuss with your group: Which design elements seemed to make your bridge stronger? Was it the use of ribs, the infill pattern, or the overall shape?”
  • Guiding Questions:
    • “Did bridges with more ribs or trusses perform better?”
    • “How did the use of fillets or chamfers affect the durability?”
    • “Was there any difference in strength due to print orientation or wall thickness?”
  • Teacher Support:
    • Facilitate discussion by prompting groups to share their findings and ideas.
3. Introduction to Optimization Techniques (15 minutes)
  • Explain Optimization:
    • “Optimization means improving your design to make it as strong as possible while using the least amount of material and time. It’s about finding the best balance between strength and efficiency.”
  • Discuss Key Concepts:
    • Infill Density:
      • “Using 100% infill makes an object very heavy and uses lots of material. Instead, we can use a lower density with special structures like ribs or trusses to make it strong without extra weight.”
    • Ribs and Trusses:
      • “Ribs are thin supports that run along your design to add strength. Trusses are like a network of small triangles that reinforce the structure.”
    • Fillets and Chamfers:
      • “Fillets are smooth, rounded edges that help distribute stress and reduce the risk of cracks. Chamfers are beveled edges that also help reduce stress at corners.”
      • “In TinkerCad, you can add fillets by using a fillet shape from the community shapes and create chamfers by positioning triangles along the edges.”
  • Show Example Models:
    • “Here’s a diagram of a bridge design before and after optimization. Notice how adding ribs and rounded edges improved the strength without using extra material.”
  • Hands-On Activity:
    • “With your group, discuss how you might optimize your bridge design based on the test results. Write down at least one idea for improvement for each key area (infill, ribs/trusses, fillets/chamfers).”
4. Sharing Insights and Feedback (15 minutes)
  • Group Presentations:
    • “Now, each group will share their insights on the test results and their ideas for optimizing their bridge designs. Explain which design elements worked well and what changes you think could make your bridge stronger.”
  • Peer Feedback:
    • Encourage groups to ask questions and offer suggestions to each other.
    • “Listen carefully to what your classmates say. Think about how their ideas might help you improve your own design.”
  • Teacher Support:
    • Provide positive reinforcement and additional suggestions if needed.
    • “Great idea using more trusses to reduce material without losing strength!”
5. Conclusion and Next Steps (5 minutes)
  • Summarize the Session:
    • “Today, we reflected on our bridge tests, discussed what design elements made your bridges strong, and learned about optimization techniques to improve strength and efficiency.”
  • Preview Next Session:
    • “In our next class, you’ll have the opportunity to refine your bridge designs based on today’s feedback and then prepare them for a final printing and testing round.”
    • “Keep thinking about how to balance strength with material efficiency. Your insights today will help you build even better bridges in the future. Great work, everyone!”
  • Optimization: Improving a design to make it as effective as possible with minimal material and time.
  • Infill Density: The percentage of the inside of a model that is filled with material; lower densities use less material but may be weaker.
  • Ribs: Thin supports added to a design to increase strength without adding much weight.
  • Trusses: A network of small triangles used to reinforce a structure.
  • Fillets: Rounded edges that help distribute stress and prevent cracks.
  • Chamfers: Beveled edges that reduce stress at the corners of a design.
  • DFAM (Design for Additive Manufacturing): Guidelines for designing 3D models that print successfully and are functional.
  • Dimensional Accuracy: How closely a printed object matches the intended dimensions in the design.
  • Rotational Motion: Movement where an object rotates around an axis or pivot point.
