Session 5: “Printing Our Creations”
In this session, Grade 5 students will see their 3D designs come to life as they watch their creations being printed. The teacher will explain the entire printing process, including slicing and how the 3D printer builds objects layer by layer. Students will learn about the responsibilities involved in slicing their models and will participate in setting up the print. By observing the printing process and taking notes, students will gain a deeper understanding of how their digital designs are transformed into physical objects.
- Understand the Printing Process: Learn how a 3D printer creates objects from digital designs by building them layer by layer.
- Learn About Slicing: Understand what slicing is and why it is an essential step before printing.
- Prepare for Printing: Gain hands-on experience in setting up a 3D print.
- Observe and Take Notes: Watch the printing process and document key observations.
- Appreciate the Transition from Digital to Physical: Recognize how precise measurements and design translate into tangible objects.
- Demonstration Videos: Short clips showing the slicing process and how a 3D printer builds objects layer by layer.
- Step-by-Step Guides: Simple screenshots or slides outlining the slicing and printing steps.
- Example Prints: Display partially printed objects to illustrate layer-by-layer construction.
- Infographics: Visual guides explaining slicing and the printing process.
Computers or Tablets:
- For accessing slicing software (e.g., Cura) and following along with demonstrations.
3D Printer:
- Set up and ready to print student designs.
Interactive Whiteboard or Projector:
- For live demonstrations of slicing and setting up prints.
Printed Models:
- Pre-designed models to demonstrate the printing process.
Notebooks and Pens:
- For students to take notes on the printing process and their observations.
Assistants or Volunteers:
- Additional adults to help guide students through setting up the print and managing the printer.
1. Introduction and Linking to Previous Sessions (10 minutes)
Greet the Students:
- “Good morning, Grade 5! Today is an exciting day—we’re going to watch your designs come to life through 3D printing.”
Recap Previous Sessions:
- “Last time, you finalized your designs and prepared them for printing by fixing any issues and exporting them as STL files. Today, we’ll take the next step and see how those designs are printed.”
Present the Session Overview:
- “We’ll learn about the slicing process, how the 3D printer builds your objects layer by layer, and you’ll get to help set up your prints. You’ll also observe the printing process and take notes on how your designs are created.”
2. Understanding the 3D Printing Process (15 minutes)
Explain Slicing:
- “Before your design is printed, it needs to be sliced. Slicing is like cutting your design into very thin layers so the printer knows how to build it one layer at a time.”
Demonstrate the Slicing Process:
- Step-by-Step Demonstration:
- Open Slicing Software (e.g., Cura):
- “We’ll use Cura to slice our models. Let me show you how it works.”
- Import the STL File:
- “First, we open Cura and import your STL file by clicking on ‘Open File’ and selecting your design.”
- Adjust Slicing Settings:
- “Here, we can adjust settings like layer height, print speed, and infill density to make sure your print comes out just right.”
- Slice the Model:
- “Once we’re happy with the settings, we click ‘Slice’. Cura will now cut your model into layers and prepare it for printing.”
- Save the G-code File:
- “After slicing, we save the file as a G-code, which is what the printer uses to build your object.”
Explain How the Printer Builds the Object:
- “The 3D printer reads the G-code and starts building your object one layer at a time. It moves the print head to lay down each layer of plastic, stacking them until your object is complete.”
3. Setting Up the Print (10 minutes)
Explain the Setup Process:
- “Now, we’ll set up the printer to start printing your designs. This involves loading the G-code file and preparing the printer.”
Hands-On Activity:
- Load the G-code File:
- “We’ll transfer the G-code file to the printer using a USB drive or direct connection.”
- Prepare the Printer:
- “Make sure the printer has enough filament loaded and the print bed is clean and ready.”
- Start the Print:
- “Press the ‘Start’ button to begin printing. The printer will start building your object layer by layer.”
Hands-On Practice:
- “Now, let’s take turns helping to set up the printer. Choose a partner and follow the steps to load and start your print.”
Teacher and Assistant Support:
- Circulate the room to assist students with loading files and starting the print.
- Ensure safety by supervising the handling of the printer.
4. Observing the Printing Process (15 minutes)
Explain What to Watch For:
- “As the printer builds your object, watch how it lays down each layer. Notice the movement of the print head and how the object starts to take shape.”
Hands-On Observation:
- “Let’s watch a print in progress. Take notes on what you see happening at each stage.”
Encourage Note-Taking:
- “Write down any interesting things you observe, like how long each layer takes to print or how the printer moves.”
- Point out key parts of the printing process and answer any questions students might have.
- Ensure students are safely observing the printer.
5. Reviewing the Printed Objects (5 minutes)
Show Completed Prints:
- “Look at the objects that have finished printing. Compare them to your designs. How did the printing process affect the final product?”
Discussion:
- “Did the printed object match your design? What did you notice about the layers and overall structure?”
Provide Positive Feedback:
- “Great job on your designs! It’s amazing to see how precise measurements helped create functional objects.”
Summarize the Session:
- “Today, you saw how your digital designs are transformed into real objects through 3D printing. You learned about slicing, how the printer builds your models layer by layer, and got hands-on experience setting up a print.”
Preview Next Session:
- “In our next class, we’ll dive into post-processing your prints, like removing supports and smoothing surfaces to make your objects even better.”
Closing Encouragement:
- “Keep thinking about how precise measurements and careful design make your creations functional and awesome. Great work today!”
- Slicing: The process of dividing a 3D model into thin layers so the printer knows how to build it.
- G-code: The set of instructions that tells the 3D printer how to move and build each layer of the model.
- Layer Height: The thickness of each individual layer in a 3D print, affecting the print’s detail and speed.
- Print Speed: How fast the printer moves while printing, which can affect the quality and time it takes to print.
- Infill Density: The amount of internal structure within a 3D print, affecting its strength and weight.
- Overhang: A part of the model that extends outward without support, which can cause printing issues if not managed properly.
- Thin Walls: Walls that are too narrow, making them fragile or difficult to print.
- DFAM (Design for Additive Manufacturing): Guidelines to design 3D models that print successfully and are functional.
- Extrusion: The process of adding height to a 2D sketch to create a 3D object.
- Precision: The quality of being exact and accurate in measurements and design.
