[DL82] Advanced Onshape Techniques
Session 2: “Advanced OnShape Techniques: Bringing Ideas to Life”
In this session, Grade 8 students will deepen their digital design skills in OnShape by exploring advanced modeling techniques. They will learn how to use powerful tools such as lofts, sweeps, and complex assemblies to transform their creative ideas into intricate 3D models. This session will build on the fundamentals they learned in previous grades, pushing them to create designs with smooth transitions and complex geometries that reflect real-world applications.
Placeholder for advanced OnShape modeling demonstration: [Google Image Search “OnShape loft sweep complex assemblies grade 8”]
  • Create Smooth Transitions Using Loft: Connect multiple profiles to form complex shapes with seamless curves.
  • Generate 3D Forms with Sweep: Use the sweep tool to extrude a profile along a defined path, creating objects with continuous cross-sections.
  • Build Complex Assemblies: Combine multiple parts into one coherent model, ensuring that different components fit together accurately.
  • Apply Advanced Modeling Techniques: Use these tools to design intricate models based on their own creative ideas and real-world constraints.
  • Prepare for Professional-Grade Projects: Enhance their ability to produce detailed, high-quality models suitable for further refinement, prototyping, or manufacturing.
  • Placeholder: [Google Image Search “OnShape loft tool demonstration”] – Example image showing lofted geometry.
  • Placeholder: [Google Image Search “OnShape sweep tool example”] – Screenshot of a model created using the sweep tool.
  • Placeholder: [Google Image Search “OnShape complex assembly”] – An image showcasing a multi-component assembly in OnShape.
    One per student or pair, with OnShape logged in and accessible.
    For live demonstrations of lofts, sweeps, and assemblies.
    For students to take notes, sketch ideas, and record observations.
    Additional support to help guide students through advanced techniques.
  • Welcome and Context:
    • “Good morning, Grade 8! Today, we’re taking your digital design skills to the next level with advanced OnShape techniques.”
  • Recap of Fundamental Skills:
    • “Let’s briefly review what you’ve learned so far—creating precise, closed sketches and basic extrusions. These skills are the foundation for the advanced techniques we’ll use today.”
  • Overview of Advanced Techniques:
    • “Today, we’ll focus on lofts, sweeps, and assembling complex models. These tools will help you create smooth, intricate 3D forms that mirror real-world engineering designs.”
2. Advanced Modeling Techniques (35 minutes)
  • Lofting (15 minutes):
    • Explanation:
      • “Lofting allows you to create a smooth transition between two or more profiles. Imagine blending different shapes to create an organic form—like a vase that gradually changes shape from top to bottom.”
    • Live Demonstration:
      • “I’ll show you how to loft between a circular profile and a square profile to create a unique, blended shape.”
      • “Now, try creating your own loft. Choose two profiles in your sketch and use the loft tool to blend them together. Experiment with different profiles and transition settings.”
  • Sweeping (10 minutes):
    • Explanation:
      • “The sweep tool takes a 2D profile and moves it along a defined path to create a 3D object. This is perfect for creating items like rails, pipes, or decorative moldings.”
      • “Watch as I create a simple pipe by sweeping a circle along a curved path.”
      • “Use the sweep tool on one of your sketches. Define a path for your profile and observe how it forms a continuous 3D object. Adjust the settings until you achieve the desired result.”
  • Complex Assemblies (10 minutes):
    • Explanation:
      • “Complex assemblies involve combining multiple components into a single model. This allows you to build more detailed and functional designs, such as a multi-part desk organizer or a mechanical component with interlocking parts.”
      • “I’ll show you how to create and assemble different components, ensuring they fit together perfectly.”
      • Placeholder: [Google Image Search “OnShape complex assembly example”]
      • “Work with your partner or group to create a small assembly. Focus on aligning and connecting parts accurately.”
3. Sharing and Peer Feedback (10 minutes)
  • Student Presentations:
    • “Let’s have a few teams share the models they created. Explain which advanced technique you used—whether it was lofting, sweeping, or assembling multiple components—and how it improved your design.”
  • Feedback Session:
    • Encourage classmates to provide constructive feedback.
    • “What did you like about each design? What ideas do you have for further improvement?”
4. Conclusion and Next Steps (5 minutes)
  • Session Summary:
    • “Today, you learned how to use advanced OnShape techniques like lofts, sweeps, and complex assemblies to bring your creative ideas to life.”
  • Preview of Next Session:
    • “In our next session, we’ll take these detailed digital models and prepare them for physical prototyping and further refinement. Your advanced techniques today will serve as a solid foundation for even more complex projects.”
    • “Great work today, Grade 8! Your creativity and precision are paving the way for professional-level design skills. Keep exploring and refining your techniques!”
  • Loft: A tool that creates a smooth transition between two or more different profiles.
  • Sweep: A tool that moves a 2D profile along a defined path to generate a 3D object.
  • Complex Assembly: Combining multiple separate components into one unified 3D model.
  • Geometric Constraints: Rules applied in sketches to ensure relationships like parallelism and perpendicularity.
  • Closed Sketch: A 2D sketch where all lines connect, essential for operations like extrusion and revolving.
  • Extrusion: The process of adding depth to a 2D sketch to create a 3D object.
