[RL85] Grade 8 - Session 5
Session: Automated Sorting Challenge – Sensitive or Not?
Duration: 60 minutes
  • Implement Conditional Logic: Use conditional statements to categorize items based on multiple factors (sensitivity and weight).
  • Understand and Operate Motor Attachments: Use the motor and dumper attachments to move and sort items.
  • Refine Navigation and Line Following: Program the robot to follow a line path and adjust directions for specific sections.
  • Dynamic Decision-Making Based on User Input: Utilize Web BLE to prompt users for item details that impact the robot’s sorting behavior.
  • Problem-Solving and Collaboration: Design a sorting system with team collaboration and test it in real time.
  • M3D Robotics kit with line and distance sensors
  • Motor attachments for moving objects: dumper, forklift
  • Laptops with Arduino IDE and Web BLE setup
  • USB/OTG cables for robot-laptop connections
  • Colored tape for marking sorting sections
  • Small objects (e.g., blocks, labeled by weight and sensitivity)
  • Art supplies for decorating sorting sections and items
  • Projector for live code demonstration
1. Introduction to Sorting Criteria and Setup (5 minutes)
The teacher introduces the session by explaining that students will create an automated sorting system in which their robot will handle items with different properties. The robot will:
  • Determine if an item is sensitive or non-sensitive (handling fragile items separately).
  • Check if the item is heavy or light.
  • Sort items into four sections based on these properties.
“Why might we want to handle sensitive items differently from non-sensitive ones?”
“What are some examples of sensitive items in real life, and how do you think they should be handled differently from non-sensitive items?”
2. Motor Attachments Overview (5 minutes)
The teacher introduces the motor and attachments, showing how they can be used for sorting tasks. Explain how each motor type works:
  • Motor Attachments: Showcase the dumper and forklift attachments.
    • Demonstrate using the commands:
      • HingeA.open() or HingeA.close(): fully raises or lowers the dumper.
      • HingeA.setAngle(): sets the dumper to a specific angle. Emphasize that the code might use HingeA or HingeB depending on the connected motor.
  • Demo Activity: Show the dumper raising and lowering to release an object and allow students a brief trial to set the angle.
Guide students in understanding how these attachments could be useful in real-world warehouse sorting.
3. Designing Sorting Arena and Preparing Items (15 minutes)
Students work in groups to set up a sorting arena with marked sections for:
  • Heavy Sensitive
  • Light Sensitive
  • Heavy Non-Sensitive
  • Light Non-Sensitive
Materials Needed:
  • Black tape to mark the four sections
  • Labeled objects with weight and sensitivity characteristics
  • Art supplies to decorate sections and items
Assist students in setting up the arena, ensuring clear labeling of each section.
4. Coding Sorting Logic with Web BLE Inputs (20 minutes)
Students program the robot to take two user inputs via Web BLE:
  1. Sensitivity (whether the item is sensitive or non-sensitive).
  2. Weight (whether the item is heavy or light).
Based on these inputs, the robot will navigate to the correct section using the dumper attachment.
Coding Steps:
  1. Getting User Input for Sensitivity and Weight:
    • Prompt the user with Web BLE: “Is the item sensitive or non-sensitive?”
    • Then prompt for weight: “Is the item heavy or light?”
  2. Determining Sorting Section Based on Inputs:
    • If sensitive and heavy: turn left to navigate to the “Heavy Sensitive” section.
    • If sensitive and light: go straight to the “Light Sensitive” section.
    • If non-sensitive and heavy: turn right to “Heavy Non-Sensitive.”
    • If non-sensitive and light: turn around to “Light Non-Sensitive.”
    if (line.onTheLine()) {
        go.forward(50);
    String Object = remote.askString("Has the item been placed?");
    if (Object == "Yes") {
        String sensitivity = remote.askString("Is the item Sensitive or Non-Sensitive?");
        String weight = remote.askString("Is the item Heavy or Light?");
        if (sensitivity == "Sensitive" && weight == "Heavy") {
            display.text("Heavy Sensitive");
            go.turnLeft();
            go.forward(50);
            if (range.get_cm() < 5) {
                HingeA.open();
        else if (sensitivity == "Sensitive" && weight == "Light") {
            display.text("Light Sensitive");
            go.forward(50);
                HingeA.open();
        else if (sensitivity == "Non-Sensitive" && weight == "Heavy") {
            display.text("Heavy Non-Sensitive");
            go.turnRight();
            go.forward(50);
                HingeA.open();
        else if (sensitivity == "Non-Sensitive" && weight == "Light") {
            display.text("Light Non-Sensitive");
            go.spinClockwise(180);
            go.forward(50);
                HingeA.open();
Guide students through the code and help them understand how the conditions direct the sorting location.
“How might the robot handle different types of objects better with these conditions?”
“In real-life warehouses, why is it important to know both the weight and sensitivity of an item?”
5. Testing and Debugging (10 minutes)
Students test their code by placing labeled items and observing whether the robot correctly identifies and sorts them.
Support students in debugging, providing guidance for logic issues, and encourage them to adjust variables to improve performance.
6. Wrap-Up and Reflection (5 minutes)
“What challenges did you encounter when sorting items based on sensitivity and weight?”
“How could you improve your robot’s sorting ability in a real-world warehouse?”
“Can you think of any other scenarios where combining two conditions might be helpful?”
Students will understand how to use conditions to make decisions based on multiple factors, practice input-based decision-making, and apply robotics in a warehouse setting. They will create a functional sorting system that reacts dynamically to object characteristics, reinforcing logic and problem-solving skills in robotics.
