Session 3: “First Prints: Bringing Designs to Life”
In this session, Grade 8 students will take their advanced models—created using the loft or sweep tools—and prepare them for 3D printing. The session is divided into two parts: first, finalizing and optimizing their digital designs for hollow objects like vases or other container-like items, and second, setting up these models in Cura for printing. This session bridges advanced modeling with practical 3D printing skills, ensuring that students learn both design refinement and slicer setup for a successful print.
Placeholder for OnShape vase example: [Google Image Search “OnShape vase loft sweep”]
Placeholder for Cura slicing interface: [Google Image Search “Cura slicing interface”]
- Finalize Advanced Designs: Optimize their models, ensuring they are fully defined and suitable for 3D printing, focusing on hollow objects like vases.
- Utilize Loft and Sweep Tools Effectively: Refine designs created with these tools to achieve smooth transitions and efficient structures.
- Set Up Slicer Parameters: Import STL files into Cura and adjust settings such as layer height, infill density, and supports to optimize print quality.
- Understand the Connection Between Design and Print: Recognize how the design details influence the printing process and the quality of the final printed object.
- Placeholder: [Google Image Search “OnShape vase design”] – Examples of advanced hollow models using loft or sweep.
- Placeholder: [Google Image Search “Cura slicer settings vase”] – Screenshots showing optimal slicer settings for hollow objects.
- Placeholder: [Google Image Search “3D printed vase prototype”] – Images of printed hollow models.
- Computers or Tablets:
With OnShape open, designs accessible, and Cura installed. - 3D Printer:
Set up and ready to print. - Interactive Whiteboard or Projector:
For live demonstrations of design finalization and slicer setup. - Notebooks and Pens:
For students to record observations and settings. - Assistants or Volunteers:
To support students during design refinements and printer setup.
1. Finalizing Digital Designs (30 minutes)
- Review and Optimize Models (15 minutes):
- “Begin by opening your advanced models in OnShape that you created using the loft or sweep tools. Today, focus on final adjustments to ensure your design is optimized for printing.”
- Key Points to Address:
- Check that the model is fully closed and defined.
- Verify that hollow areas (such as in a vase) have proper wall thickness and internal support.
- Refine curves and transitions to ensure smooth surfaces.
- Example: “Consider a vase design—ensure the body is hollow, the transitions are smooth, and any overhangs are minimized to reduce the need for supports.”
- Hands-On Activity:
- Students work in pairs or individually to make final tweaks. Teachers and assistants circulate to provide guidance.
- Exporting as STL:
- “Once your design is finalized, export your model as an STL file. In OnShape, select your part from the parts menu, right-click, choose ‘Export,’ select STL, and save it to your computer.”
- Placeholder: [Google Image Search “OnShape export STL”]
2. Setting Up the Print in Cura (30 minutes)
- Importing and Adjusting Slicer Settings (15 minutes):
- “Open Cura and import your STL file.”
- Key Settings to Adjust:
- Layer Height: Set to 0.1–0.2 mm for detailed prints.
- Infill Density: For hollow objects like vases, use a lower infill (around 10–20%) or opt for an optimized infill pattern that maintains strength without wasting material.
- Supports: Enable supports for any overhanging parts if necessary.
- Print Orientation: Ensure your model is oriented to minimize overhangs and maximize strength.
- “Use the Preview mode in Cura to examine how your model is sliced into layers.”
- Initiating the Print (15 minutes):
- “After adjusting your settings, send the file to the 3D printer. Watch as the printer builds your model layer by layer, and note any observations about print quality and accuracy.”
- “Discuss with your team how the chosen slicer settings might affect the final product, and record any areas for improvement.”
- Placeholder: [Google Image Search “3D printer layer by layer”]
3. Conclusion (5 minutes)
- Wrap-Up Discussion:
- “Today, you finalized your digital designs and set them up for printing. Your attention to detail in both the design and slicer settings plays a critical role in the quality of your printed objects.”
- Next Steps:
- “In our next session, we will focus on post-processing your prints to further enhance their appearance and functionality.”
- Closing Encouragement:
- “Great work today! Your ability to optimize designs and adjust print settings shows your growing expertise. Keep refining your skills as you move forward!”
- Loft: A tool that creates a smooth transition between multiple profiles to form a 3D shape.
- Sweep: A tool that extrudes a 2D profile along a defined path to create a continuous 3D object.
- Closed Model: A 3D model where all surfaces are connected without gaps, essential for successful printing.
- STL File: A file format that contains the 3D geometry of your model, used for 3D printing.
- Slicer: Software that converts a 3D model into layers and generates G-code for the printer.
- Layer Height: The thickness of each printed layer, affecting detail and print time.
- Infill Density: The percentage of material used inside a printed model, balancing strength and material usage.
- Supports: Temporary structures added during printing to hold up overhanging parts.
- Print Orientation: The position of the model on the print bed, which affects strength and print quality.
Exporting as STL:
- Next Steps:
