[RL5] Grade 5 -- Curriculum Overview
Session Length: 50 - 60 minutes
Learning Style: Project-based, exploration, collaborative problem-solving
Key Learnings (Sessions 1-10):
  • Session 1-2: Advanced Scratch coding introduction, focusing on loops and conditionals.
  • Session 3-4: Using sensors to navigate terrain autonomously; obstacle detection.
  • Session 5-6: Line-following challenges combined with decision-making (e.g., turning based on sensor input).
  • Session 7-8: Introduction to interacting bots (two bots collaborating to achieve a task).
  • Session 9-10: Project-based challenge: design a solution to move objects using the bot’s dumping bucket or actuators.
Equipment Needed: M3D Go Robotics kit with multiple sensors, M3D Scratch, line-following tracks, small objects for dumping, multiple bots.
Course Breakdown
1. Intro to Scratch & Robot
This session introduces students to Scratch, focusing on basic movement commands. Using the on-screen gamepad, students manually control the robot through basic tasks (move forward, backward, turn left, and right). They will explore how to issue commands via Scratch’s drag-and-drop interface.
2. Loops: Keep Moving
Students will be introduced to the concept of loops to make the robot repeat movements without manually repeating the same blocks. The task will be to make the robot move in a continuous square pattern by using “repeat” loops.
3. Track and Change: The World of Variables
In this session, students will learn about variables in Scratch, exploring how they can store and change values in their programs. The instructor will introduce built-in variables and show how to create custom ones. Students will program their robots to track things like steps or tasks completed, experimenting with how changing variable values affects the robot’s behavior. By the end, they will understand how variables bring flexibility and dynamic responses to their coding projects.
4. Decision Time: What Will Your Robot Do
In this session, students will learn about conditional logic using “if-then” and “if-then-else” blocks in Scratch. The instructor will guide them on how these blocks help the robot make decisions, like performing different actions based on user input. Students will create programs where the robot reacts to different conditions, such as showing an emoji or moving in a direction when a button is pressed. After coding, they will test their programs to see how the robot responds in real-time.
5. Collision Detector
Students will integrate the distance sensor and program the robot to avoid obstacles. The bot will move forward and stop when it detects an obstacle within a certain distance. This reinforces the idea of conditionals and introduces sensor data to control the robot’s behavior.
6. Line Follower Fun
Students will use the line-following sensor for the first time. The instructor will show how to program the robot to follow a black line drawn on the floor or table. This introduces the idea of conditional logic, where the robot will react differently based on sensor input (e.g., stay on the line).
7. Dumping Bot: Carry and Drop
Students will use the servo motor and dumping bucket in this session. The robot will be programmed to move to a location, pick up a small object using the bucket, and then drop it at a designated area. This introduces simple conditionals (“if-then” logic) to execute tasks based on timing or sensor input.
8. Follow the Leader
In pairs, students will program one bot to follow another using the distance sensor. The lead bot will move in a pre-programmed pattern, while the second bot uses its sensor to maintain a set distance. This is a gentle introduction to multi-bot interaction.
9. Bot Relay Race
In teams, students will program two robots to collaborate in a relay-style race. One bot will navigate through an obstacle course using line-following or distance sensors, then hand off a small object to the second bot, which will complete the course. This solidifies the concepts of collaboration, sensor integration, and conditionals.
10. Final Challenge: Rescue Mission
In this culminating activity, students will bring together all their learning. Their bot will map out a small area, avoid obstacles, collect objects with its bucket, and deliver them to a target location. This task will involve loops, conditionals, sensor input, and mapping, testing everything they’ve learned throughout the sessions.
