[RL73] Grade 7 - Session 3
Session 3: Endless Moves: Loop Logic
  • M3D Robotics kit (M3D Go)
  • Laptops with Arduino IDE
  • Projector for live coding demonstrations
  • Understand variables as containers for storing data values.
  • Explore basic types of variables and how to use them in code.
  • Learn for loops for repeating actions a specified number of times.
  • Apply loops with movement, display messages, and sensor readings to control the robot’s behavior.
1. Introduction to Variables (15 minutes)
Start with a hands-on activity to introduce the concept of variables as a way to store and manipulate data in code. This sets up a foundation for using variables with loops.
  1. Visualizing Variables:
Begin with an empty container or cup, explaining that variables are like containers where we store values temporarily. You can start as follows:
"Think of this container as a variable. Right now, it’s empty, but we can add coins to it, just like putting points into a game score. When we need the value, we can pull it out or change it.”
  • Write “Coins:” on the board and hand out coins to students.
  • Encourage them to add the coins in the cup and change the value of the variable “Coins” as they add coins in it.
  1. Demonstrate Variable Usage:
Write code to create and assign a simple variable on the projector.
  • Example Code:
    int score = 0;  // Creates a variable named 'score' and sets it to 0
Explain that int means it’s a whole number. You may say:
“Here, ‘score’ is a variable that starts at zero. As we play, we can increase this score. Just like you count points in a game, we count values with variables.”
  1. Types of Variables:
    Introduce a few basic variable types with examples:
    • int (integer): Stores whole numbers, like scores or counts.
    • float (floating-point): Stores numbers with decimals, like distances or measurements.
    • String: Stores text, like messages to display on the screen.
    • bool: Stores the status true or false of a state to be used in conditions.
    • Example Code:
      int count = 5;           // Stores a whole number
      float distance = 15.6;    // Stores a number with decimals
      String greetings = "Hello"; // Stores text
You can explain each variable as you code them on the projector screen:
“Just like you can put different items in a container, you can store different kinds of data in variables. int is for whole numbers, float for decimals, and String for text.”
2. Introduction to Loops (10 minutes)
Begin with a discussion on the need for repeating actions in code, introducing for loop.
Discussion Examples:
“Have you ever clapped ten times in a row or counted steps? Instead of writing the same instruction multiple times, we can say ‘Clap ten times,’ and everyone knows what to do. A for loop helps us repeat actions like this.”
Introduce for loops and demonstrate a basic example on the projector.
You main explain the syntax by breaking it down in three parts:
  • Variable initialization/Defining the variable
  • Condition
  • Variable change
for(i = 0, i<10, i++){
display.text("Clap!");    // Instructions to be repeated
Example Code for For Loop:
    for (int i = 0; i < 3; i++) {    // Repeat actions 3 times
        go.forward(50);              // Move forward at 50% speed
        go.delay(1000);               // Move for 1 second
        go.stop();                    // Stop
        go.delay(500);                // Wait for 0.5 seconds
Explanation:
“This for loop repeats three times. Each time, the robot moves forward, shows ‘Step’ and the step number, waits, then stops. The i variable keeps count.”
Encourage students to change the loop count and observe the changes.
3. Hands-On Challenges (30 minutes)
Encourage students to apply for loop, using movement, display messages, and distance readings.
Challenge 1: Forward and Spin Repeat
  • Task: Program the robot to move forward and spin clockwise, repeating five times using a for loop.
    for (int i = 0; i < 5; i++) {
        go.forward(50);
        display.text("Forward Step " + String(i+1));
        go.delay(1000);
        go.spinClockwise(50);
        display.text("Spinning");
        go.delay(500);
Challenge 2: Loop Counter on Display
  • Task: Use a for loop to make the robot move forward 3 times and display the loop count each time.
    for (int i = 1; i <= 3; i++) {
        go.forward(50);
        display.text("Loop " + String(i));   // Display loop count
        go.delay(1000);
        go.delay(500);
Challenge: Obstacle Response with State Variable
Task:
Program the robot to detect obstacles within 15 cm using the distance sensor. When it detects an obstacle, set a boolean variable (obstacleDetected) to true. If obstacleDetected is true, the robot should stop, display “Obstacle Ahead!” on its screen, and spin in place for 2 seconds. Once the spin is complete, reset obstacleDetected to false, allowing the robot to resume moving forward if the path is clear.
Goal:
Learn to use a boolean variable to create a state that triggers specific actions based on sensor input.
bool obstacleDetected = false;  // Variable to track obstacle status
    // Check if obstacle is detected within 15 cm
    if (range.get_cm() < 15) {
        obstacleDetected = true;   // Set state to true if obstacle is close
    // Perform actions based on obstacle state
    if (obstacleDetected) {
        go.stop();                    // Stop the robot
        display.text("Obstacle Ahead!"); // Display message
        go.spinClockwise(50);          // Spin in place
        go.delay(2000);                // Spin for 2 seconds
        obstacleDetected = false;      // Reset state after action
        go.forward(50);  // Continue moving if no obstacle
4. Reflection and Wrap-Up (5 minutes)
  • “How did using a for loop help you repeat actions a specific number of times?”
  • “What did you find challenging or interesting about today’s session?”
Wrap up with a discussion, reinforcing the value of variables and loops for creating efficient, flexible code that can adapt to repeated actions and specific conditions.
By the end of this session, students will understand basic variables, for loop, and use these structures in conjunction with sensor inputs and display messages to build decision-based behaviors in the robot.
