[DL51] Introduction to Advanced Sketching in TinkerCad
Session 1: “Introduction to Advanced Sketching in TinkerCad”
In this first session for Grade 5 students, we will learn how to use the new Sketch feature in TinkerCad. This tool lets you create detailed and accurate shapes using straight lines and curves. You will practice moving points, making corners smooth or sharp, and turning your drawings into 3D models. This session is an important step toward using professional design software that also uses sketching for creating detailed designs. By mastering the Sketch feature in TinkerCad, you will build the skills and confidence needed to move on to more advanced design tools in the future.
  • Master the Advanced Sketch Tool: Create detailed and complex closed surfaces using straight lines and Bezier curves in TinkerCad’s Sketch feature.
  • Manipulate Sketch Points: Learn how to move and adjust points within a sketch to refine shapes and achieve precision.
  • Transform Corners: Utilize the options to convert selected points to smooth or sharp corners, enhancing the design’s look and functionality.
  • Extrude Sketches into 3D Models: Understand how to extrude 2D sketches into 3D objects, controlling height and depth for added dimension.
  • Prepare for Professional CAD Software: Recognize how these advanced sketching techniques lay the groundwork for using more complex CAD tools in professional settings.
  • Demonstration Videos: Clips showcasing the use of the Sketch tool, including drawing, point manipulation, and extrusion.
  • Step-by-Step Guides: Detailed screenshots or slides outlining each step of the advanced sketching process in TinkerCad.
  • Example Models: Display complex models created using the Sketch feature to inspire students.
  • Infographics: Visual guides explaining the relationship between TinkerCad’s Sketch feature and professional CAD software.
    • One per student or pair, with TinkerCad logged in and ready to use.
    • Internet access for downloading example images if needed.
    • For live demonstrations of advanced sketching techniques.
1. Introduction and Session Overview (10 minutes)
    • “Good morning, Grade 5! Today, we’re going to dive deeper into 3D modeling by exploring the advanced Sketch feature in TinkerCad.”
  • Present the Session Overview:
    • “We’ll learn how to create detailed and complex closed surfaces using straight lines and curves, move points to refine our shapes, make corners smooth or sharp, and turn our sketches into 3D models. These skills will help you create more intricate designs and prepare you for using professional CAD software in the future.”
  • Highlight the Importance:
    • “Understanding these advanced sketching techniques is essential as it builds the foundation for more sophisticated design tools used by professionals in engineering, architecture, and various design fields.”
2. Mastering the Advanced Sketch Tool (15 minutes)
  • Explain the Advanced Sketch Tool:
    • “The Sketch tool in TinkerCad allows us to draw precise closed surfaces using straight lines and Bezier curves. This tool gives you the freedom to create unique and detailed shapes that are essential for complex 3D models.”
  • Demonstrate the Sketch Tool:
    • Step-by-Step Demonstration:
      1. Access the Sketch Tool:
        • “Click on the ‘Create Shape’ dropdown in the sidebar and select ‘Sketch’.”
      2. Choose Drawing Mode:
        • “You have two options: Straight Lines (option 1) and Curves (option 2). Select option 1 to start with straight lines.”
      3. Draw a Closed Surface:
        • “Use your mouse or stylus to click and create straight lines that form a closed shape, such as a star or polygon.”
      4. Switch to Bezier Curves:
        • “Now, select option 2 to add curves to your sketch. Click and drag to create smooth, flowing lines that enhance your design.”
      5. Complete the Sketch:
        • “Ensure your sketch is a closed surface by connecting the last point back to the first point.”
    • “Now, try creating your own closed shape using straight lines and Bezier curves. Experiment with different shapes and combinations to see how they look in 2D.”
3. Manipulating Sketch Points and Transforming Corners (15 minutes)
  • Explain Manipulating Sketch Points:
    • “After drawing your sketch, you can move individual points to refine your shape. This allows for greater precision and customization in your designs.”
  • Demonstrate Moving Points:
      1. Select Points:
        • “Click on any point in your sketch to select it.”
      2. Move Points:
        • “Drag the selected point to a new position to adjust the shape of your sketch.”
      3. Adjust Multiple Points:
        • “Hold the Shift key and click multiple points to move them at the same time for more complex adjustments.”
  • Explain Transforming Corners:
    • “You can also change how the corners of your sketch look by making them smooth or sharp.”
  • Demonstrate Transforming Corners:
      1. Select All Points:
        • “Click and drag to select all the points in your sketch.”
      2. Transform Corners:
        • “Choose the ‘Transform’ option and select either ‘Smooth’ or ‘Sharp’ to change the corners of your sketch.”
      3. Observe Changes:
        • “Notice how changing the corners affects the overall shape and flow of your design.”
    • “Experiment with moving points and transforming corners in your sketches. Try creating both smooth and sharp edges to see how they affect your design.”
4. Extruding Sketches into 3D Models (10 minutes)
  • Explain Extrusion:
    • “Extrusion is the process of adding height to your 2D sketch to turn it into a 3D object. This adds depth and makes your design three-dimensional.”
  • Demonstrate Extrusion:
      1. Select the Sketch:
        • “Click on your completed sketch to select it.”
      2. Set Extrusion Height:
        • “In the properties panel, set the desired height for your extrusion. For example, set it to 10mm.”
      3. Extrude the Sketch:
        • “Click ‘Extrude’ to convert your 2D sketch into a 3D object.”
      4. Inspect the 3D Model:
        • “Use the viewing tools to rotate and look at your new 3D model from different angles.”
    • “Extrude your own sketches into 3D models. Adjust the height and see how your 2D designs turn into three-dimensional objects.”
5. Preparing for Professional CAD Software (5 minutes)
  • Discuss the Transition:
    • “The skills you’re learning today with TinkerCad’s Sketch feature are important foundations for professional CAD software like AutoCAD, SolidWorks, or Fusion 360. These programs use similar sketching tools but offer more advanced features for detailed and precise engineering designs.”
  • Highlight the Importance of Precision:
    • “Professional CAD software requires a high level of precision and attention to detail, just like what you’re practicing today. Mastering these foundational skills will help you use more advanced tools more easily.”
  • Encourage Future Learning:
    • “Keep practicing your sketching and modeling skills. The more you work on these, the better prepared you will be for tackling advanced design challenges in the future.”
6. Sharing and Feedback (5 minutes)
  • Invite Students to Share:
    • “Would anyone like to showcase their advanced design and explain how they used the Sketch tool to enhance their model?”
  • Provide Positive Feedback:
    • “Your detailed star design looks fantastic! The precision you used with the Sketch tool really makes it stand out.”
    • “I love how you incorporated smooth curves into your polygon—it adds a professional touch to your design.”
  • Encourage Peer Feedback:
    • “Listen to your classmates’ presentations and think about what you admire in their designs and any ideas you might apply to your own projects.”
  • Sketch Tool: A feature in TinkerCad that allows users to draw custom, freeform closed surfaces using straight lines and Bezier curves, which can then be extruded into 3D objects.
  • Bezier Curve: A smooth, flowing line used in computer graphics to create curved shapes.
  • Extrusion: The process of extending a 2D shape into the third dimension to create a 3D object.
  • Clearance: The small gap between moving parts in a model to ensure they can move freely without sticking together during printing.
  • Professional CAD Software: Advanced computer-aided design programs used by engineers and designers for creating detailed and precise 3D models (e.g., AutoCAD, SolidWorks, Fusion 360).
  • Point Manipulation: Adjusting the position of specific points in a sketch to refine and perfect the shape.
  • Transform Corners: Changing the nature of corners in a sketch to be either smooth or sharp for aesthetic and functional purposes.
  • Precision: The quality of being exact and accurate in design and execution.
