Session 2: “Advanced OnShape Techniques: Bringing Ideas to Life”
In this session, Grade 7 students will dive deeper into advanced sketching techniques in OnShape. Building on their foundational skills from Grade 6, they will learn how to apply geometric constraints and feature patterns to refine their sketches. These tools help ensure that sketches are precise, symmetric, and fully defined—qualities essential for creating complex 3D models later. Today, we will focus on understanding and using constraints (such as parallel, perpendicular, and equal constraints) and pattern tools (both linear and circular) in detail.
Placeholder for advanced OnShape constraints image: [Google Image Search “OnShape geometric constraints”]
Placeholder for OnShape pattern tool image: [Google Image Search “OnShape sketch pattern tool”]
By the end of this session, Grade 7 students will be able to:
- Apply Geometric Constraints: Use constraints (parallel, perpendicular, equal, horizontal, and vertical) to control the relationships between sketch elements.
- Use Pattern Tools Effectively: Create linear and circular patterns to replicate design features efficiently.
- Enhance Sketch Precision: Refine sketches to be fully defined and precise, laying a strong foundation for later 3D modeling.
- Placeholder: [Google Image Search “OnShape geometric constraints”] – Visual guide for applying constraints.
- Placeholder: [Google Image Search “OnShape pattern tool”] – Screenshot showing linear and circular pattern usage.
- Computers or Tablets: One per student or pair, with OnShape logged in.
- Interactive Whiteboard or Projector: For live demonstrations.
- Notebooks and Pens: For students to record steps and observations.
- Assistants or Volunteers: To help guide students through the procedures.
1. Recap of Foundational Skills (15 minutes)
- Welcome and Recap:
- “Good morning, everyone! Let’s start by reviewing the basic sketching skills we learned in Grade 6. Who remembers what a closed sketch is and why it’s important?”
- “Recall how we used simple tools like the line, arc, and circle tools to create precise sketches.”
- Brief Demonstration:
- Show a quick example of a closed sketch and how dimensions were applied.
- Placeholder: [Google Image Search “OnShape basic sketch”]
- Discussion:
- “How did precise measurements help you create strong sketches? Why is it important to have fully defined sketches?”
2. Advanced Geometric Constraints (15 minutes)
- Introduction to Constraints:
- “Geometric constraints are rules that help you control the relationships between parts of your sketch. They ensure your design stays precise and consistent.”
- Key Constraints Explained:
- Parallel Constraint:
“This makes two lines run in the same direction. For example, in a rectangle, opposite sides should be parallel.” - Perpendicular Constraint:
“This ensures that two lines meet at a 90° angle, which is important for making right angles in your design.” - Equal Constraint:
“This makes two or more elements equal in length. Use this when you want symmetry, such as in a square or circle.” - Horizontal/Vertical Constraints:
“These lock lines into horizontal or vertical positions, ensuring consistent orientation.”
- Procedure for Applying Constraints:
- Select the Sketch Element:
“Click on a line or angle in your sketch that you want to constrain.” - Choose the Constraint Tool:
“From the toolbar, select the appropriate constraint (e.g., Parallel).” - Apply the Constraint:
“Click on the other element you want to be parallel to, and the tool will lock them together.”
- Hands-On Practice:
- “Apply at least two different constraints to your current sketch. For example, make one pair of lines parallel and ensure two adjacent lines are perpendicular.”
3. Advanced Pattern Tools (25 minutes)
- Introduction to Pattern Tools:
- “Pattern tools allow you to quickly create repeated features in your sketch. This is useful for designs that have multiple identical elements, like holes in a key holder or decorative features on a desk organizer.”
- Types of Patterns:
- Linear Pattern:
“This tool creates copies of a selected element along a straight line. For example, you can replicate a hole across the length of a box.” - Circular Pattern:
“This tool arranges copies of an element around a central point. This is great for designs like a round dial or a circular arrangement of holes.”
- Linear Pattern:
- Procedure for Using Pattern Tools:
- Select the Element:
“Click on the shape or feature you want to repeat.” - Choose the Pattern Tool:
“Select either the linear or circular pattern tool from the toolbar.” - Set Parameters:
“For a linear pattern, set the number of copies and the spacing between them. For a circular pattern, set the number of copies and the angle between them (usually 360° divided by the number of copies).”
- “Now, try creating a linear pattern in your sketch by duplicating a small circle along a line. Then, experiment with a circular pattern by arranging a few elements around a center point.”
4. Sharing and Feedback (5 minutes)
- Student Sharing:
- “Would anyone like to share the improvements they made using constraints and pattern tools? Explain what tools you used and how they helped your design.”
- Peer Feedback:
- Encourage classmates to give positive feedback and share one idea they found interesting.
- Teacher Feedback:
- “Great work applying constraints! Your sketches are becoming much more precise, and the pattern tools really speed up your design process.”
5. Conclusion and Next Steps (5 minutes)
- Session Summary:
- “Today, you learned advanced sketching techniques in OnShape by applying geometric constraints and using pattern tools. These tools help you create precise, fully defined sketches that are essential for building detailed 3D models.”
- Preview Next Session:
- “Next session, we will take these refined sketches and use the extrude feature to turn them into complete 3D models.”
- Closing Encouragement:
- “Keep practicing these advanced techniques. The precision you build now will make your future designs even stronger. Great job, everyone!”
- Geometric Constraints: Rules that define relationships between sketch elements, such as parallel, perpendicular, and equal constraints.
- Linear Pattern: A tool that replicates a feature along a straight line.
- Circular Pattern: A tool that replicates a feature around a central point.
- Advanced Sketching: The process of refining sketches with precise tools to create detailed, fully defined 2D drawings.
- Closed Sketch: A sketch where all lines connect to form a complete boundary, necessary for 3D operations.
- Extrusion: The process of adding depth to a 2D sketch to create a 3D model.
