Session 6: “Designing for Strength: Optimization”
In this session, students will learn how to optimize their designs for strength and durability. They will redesign their existing models with a focus on stress distribution and reinforcing geometries—such as adding ribs, trusses, and adjusting wall thickness. Additionally, students will explore how changes in slicer settings (like infill density and support structures) can improve the final print’s strength while reducing material use and print time. This session emphasizes the importance of iterative design, where feedback and testing lead to stronger, more efficient models.
Placeholder for reinforced geometry examples: [Google Image Search “3D printed model ribs trusses”]
Placeholder for slicer settings diagram: [Google Image Search “Cura infill density settings”]
- Redesign for Strength: Modify their digital models to improve stress distribution and durability using reinforcing features (e.g., ribs, trusses, and increased wall thickness).
- Understand Stress Distribution: Explain how design changes affect the way forces are distributed through a model, reducing weak points.
- Optimize Slicer Settings: Adjust slicer parameters—such as infill density, layer height, and support settings—to enhance the strength of the printed object without excessive material use.
- Iterate on Design: Use feedback and testing results to continuously refine and improve their models.
- Placeholder: [Google Image Search “3D printed model with ribs and trusses”] – to show examples of reinforced designs.
- Placeholder: [Google Image Search “Cura infill density settings”] – a diagram illustrating different infill densities and their effects.
- Placeholder: [Google Image Search “stress distribution in 3D printed parts”] – visual explanation of how forces distribute through various geometries.
- Computers or Tablets:
With OnShape open and current design files accessible. - Slicing Software (e.g., Cura):
For adjusting and previewing changes in print settings. - Interactive Whiteboard or Projector:
For live demonstrations of design optimization and slicer adjustments. - Notebooks and Pens:
For recording observations, design changes, and test results. - Assistants or Volunteers:
Additional support to help guide students through design and slicer modifications.
1. Introduction (10 minutes)
- Welcome:
- “Good morning, everyone! Today we’re focusing on making our designs stronger and more durable.”
- Session Overview:
- “You’ll learn how to adjust your digital models for better stress distribution by adding reinforcing features like ribs and trusses, and we’ll also see how adjusting slicer settings can further optimize your prints.”
- Discussion:
- “Why do you think some parts of your model might break under pressure? Let’s talk about stress distribution and how small design changes can make a big difference.”
2. Redesigning for Strength in OnShape (25 minutes)
- Review Existing Models:
- “Open your current model in OnShape. Identify areas where your design might be weak, such as thin walls or unsupported overhangs.”
- Adding Reinforcing Features:
- Ribs and Trusses:
- “Add ribs along flat surfaces or inside hollow parts to provide extra support. Use truss patterns in areas where forces may be concentrated.”
- Increasing Wall Thickness:
- “Examine areas with thin walls and increase the thickness for added strength.”
- Ribs and Trusses:
- Live Demonstration:
- “Watch as I modify a model to add ribs and adjust wall thickness. Notice how these changes can help distribute stress more evenly.”
- Hands-On Activity:
- “Now, work on your models to incorporate these reinforcing features. Make sure your design remains fully defined and optimized for printing.”
3. Optimizing Slicer Settings (20 minutes)
- Introduction to Slicer Adjustments:
- “After you’ve reinforced your digital model, the next step is to adjust slicer settings to ensure your print is strong and efficient.”
- Key Slicer Settings:
- Infill Density:
- “Increasing infill density can add strength, but using 100% infill is not always best. Instead, use an optimal range (20–30%) combined with design features like ribs or trusses.”
- Layer Height:
- “A lower layer height improves detail and layer bonding, which can make the model stronger.”
- Support Structures:
- “Adjust support settings to ensure that overhanging areas are well-supported without excessive material use.”
- Infill Density:
- Live Demonstration in Cura:
- “Let’s open your STL file in Cura. I’ll show you how to adjust the infill density, layer height, and supports to see how each change affects the preview of your model.”
- Hands-On Practice:
- “Spend time tweaking these settings on your own model. Compare different settings in the Preview mode and note the impact on estimated print time and material usage.”
- Group Discussion:
- “Share your observations with your group. Which settings seem to give the best balance of strength and efficiency?”
4. Conclusion and Next Steps (5 minutes)
- Session Summary:
- “Today, you learned how to redesign your models for better strength by adding reinforcing features, and how to optimize slicer settings for efficient and strong prints.”
- Preview Next Session:
- “Next time, we’ll move on to finalizing your models for presentation and exploring post-processing techniques.”
- Closing Encouragement:
- “Excellent work today! Your attention to detail in both design and print settings will make your models much more durable and efficient. Keep refining your skills!”
- Ribs: Thin, internal supports added to a model to increase its strength without excessive material use.
- Trusses: A network of small triangles within a design that enhances structural stability.
- Infill Density: The percentage of the interior of a model that is filled with material, affecting strength and weight.
- Layer Height: The thickness of each layer in a 3D print, which influences detail and adhesion.
- DFAM: Design for Additive Manufacturing, a set of guidelines for creating efficient and strong 3D printed models.
- Stress Distribution: How forces are spread throughout a model; good design minimizes concentrated stress points.
- Slicer: Software that converts 3D models into printable layers and generates G-code for the printer.
