Preparing for the online test - IYPT 2027
:rocket: Big Changes Coming to IYPT 2027 Team Pakistan Selection!
PYIMS is revolutionizing the selection process for the National Team. For a comprehensive breakdown of the new criteria and pipeline, check out the IYPT 2027 Team Pakistan Selection guide.
:spiral_calendar: Key Milestones
  1. Online Selection Test: Taking place in the 2nd week of November.
  2. Mystery Box Challenge: Details to be revealed exclusively to candidates who pass the online test.
:memo: Preparing for the Online Test
The online test will be an AI-proctored exam that you can take from any location with a computer and internet access. While technical details will follow, here is how you should start preparing today.
No Syllabus? No Problem!
Unlike traditional exams, there is no set booklet or syllabus. Instead, the test is designed to push your conceptual boundaries. All questions are inspired by the Selected Problems for the 40th IYPT 2027.
:light_bulb: How to Approach Your Preparation:
  • Recreate the Phenomenon: Ask yourself, “How would I recreate this problem at home or school?” Try it physically, watch related videos, or search this forum for others’ results.
  • Deconstruct the Science: List every scientific concept involved in each problem.
  • The “What If” Method: Challenge yourself with hypothetical scenarios for every problem.
  • Bridge the Gaps: If a problem requires math or physics you haven’t learned yet, don’t panic! Use the internet or ask a teacher. You only need a solid foundational understanding for the online test phase.
:bullseye: What We Are Looking For
The test is engineered to evaluate:
  • Analytical Prowess: Your ability to answer complex questions logically.
  • Thought Experiments: How well you can simulate problems in your mind.
  • Independent Thinking: Performance in the absence of AI tools.
  • Daily Observation: Your awareness of scientific phenomena in the world around you.
  • Readiness: Your potential to start working on these problems under our guidance.
:loudspeaker: Start Today!
This is a national-level competition, and with only a few hundred spots available for the next stage, every day counts.
Questions? Drop a reply below and let’s get started!
Since there’s no particular curriculum for the test, would it be that for the test it’ll focus on more situation-based problems? or will it focus on student’s ability to isolate variables and bring out probable hypothesis that after experimentation (iteration can be a better word here) brings about the final most plausible hypothesis that can be used? Of course all in simulation.
What type of questions will appear? Short Questions/MCqs/Descriptive Qualitative/Quantitative questions. Also, will the questions generally be qualitative or quantitative? Moreover, will these be similar to questions in NPTC/IPhO. They give us a problem and we need to basically derive some things it by deriving formula for maybe acceleration or whatever depends on the problem. It mainly requires knowlege of calculus, physics and mathematical problem solving. Please also share soem sample questions.
Hi, I was checking the resources uploaded for the upcoming assessment. Given how complex these topics are, the short summaries currently on the portal aren’t enough to properly prepare. Could you please share the detailed study guides or direct me to the full learning materials for this test? Thankyou.
can you plese where are these resources? i am uanble to find
The test will include both qualitative and quantitative questions. It checks how well you understand the basic physics concepts such as velocity and forces to more advanced topics like acoustics and fluid flow.
You are not expected to be an expert in every area, but you should be familiar with each topic and able to apply it at a basic level or explain its effect on a system.
The detailed structure and sample questions will be shared in the coming weeks.
Which resources are you referring to?
The summaries on the portal are serving two purposes:
  1. It provides a breakdown of the problem statement into its basic concepts without you having to design or perform the experiment.
  2. It gives you the direction as to which topics you have to cover for the test.
Other than that, you can study these concepts from your school curriculum as well as online resources.
I would reiterate. You are not expected to be an expert in every area, only that you should be familiar with each topic and able to apply it at a basic level or explain its effect on a system.
