[DL44] Finalizing Designs for Printing
Session 4: “Finalizing Designs for Printing”
By the end of the session, Grade 4 students will:
  • Complete Their Functional Designs: Finalize their TinkerCad projects, ensuring all components are accurately modeled.
  • Identify and Correct Common Design Issues: Learn to spot and fix unconnected parts, excessive overhangs, and other common 3D printing challenges.
  • Optimize Models for Printing: Adjust designs to enhance printability, including wall thickness, support structures, and model orientation.
  • Prepare Files for Printing: Export their finalized designs in the appropriate file format and understand the basics of file preparation for 3D printing.
  • Understand Design-to-Print Workflow: Gain a clear understanding of the steps required to transition from a digital model to a physical object.
  • Examples of Well-Prepared and Problematic Designs:
    • Models with unconnected parts
    • Designs with excessive overhangs
    • Correctly grouped and aligned models
  • Step-by-Step Guides:
    • Screenshots or slides illustrating common issues and their solutions in TinkerCad
  • Sample Designs:
    • Pre-designed functional objects showcasing optimal design practices
    • One per student or pair, with TinkerCad already logged in and their designs open
    • Preferably with internet access for referencing community shape libraries if needed
    • For demonstrating design checks and corrections
    • Displaying examples of common design issues and best practices
  • Drawing Materials:
    • Paper and pencils for sketching modifications or planning fixes
    • Additional adults to help guide students during the session
  • Safety Equipment:
    • Ensure students are aware of safe computer usage practices and the importance of handling printed objects carefully
    • “Good morning, everyone! Welcome back to our 3D design sessions.”
  • Recap Previous Session:
    • “Last time, we designed functional objects like desk organizers and keychains using TinkerCad. Who remembers some of the tools we used?”
  • Introduce Today’s Theme:
    • “Today, we’re going to make sure our designs are perfect for 3D printing. We’ll check for any issues and prepare our files so that our creations can come to life!”
2. Understanding Common Design Issues (10 minutes)
  • Explain Common Issues:
    • “Before we print our designs, we need to make sure there are no problems that could make printing difficult or cause our objects to fail.”
  • Show Examples:
    • Unconnected Parts:
      • Display a model with separate, unconnected components.
      • “See how these parts aren’t connected? If we try to print this, the parts might not stay together.”
    • Excessive Overhangs:
      • Show a model with parts extending too far without support.
      • “These overhangs can cause the print to sag or collapse because there’s nothing to hold them up.”
    • Thin Walls:
      • Display a model with walls that are too thin.
      • “Walls that are too thin can break easily or not print properly.”
  • Discussion:
    • “Can anyone think of why it’s important to fix these issues before printing?”
3. Guided Demonstration: Checking and Fixing Designs in TinkerCad (15 minutes)
  • Demonstrate Design Checks:
    • Step 1: Inspecting the Model
      • “Let’s take a look at our designs and see if there are any unconnected parts.”
      • Use the “Align” and “Group” tools to ensure all components are connected.
    • Step 2: Addressing Overhangs
      • “If your design has overhangs, think about how you can add support or adjust the angle to reduce them.”
      • Show how to add support structures using simple shapes.
    • Step 3: Ensuring Proper Wall Thickness
      • “Check that your walls are thick enough to be strong. A good rule of thumb is at least 1.5 mm thick.”
      • Demonstrate adjusting wall thickness in TinkerCad.
  • Interactive Q&A:
    • “Does anyone see an issue in their design that we can fix together?”
    • Assist students in identifying and correcting problems in their own models.
4. Hands-On Activity: Finalizing Designs (20 minutes)
  • Activity Overview:
    • “Now, it’s your turn to finalize your designs. Make sure there are no unconnected parts, overhangs are minimized, and walls are thick enough.”
  • Instructions:
    • Step 1: Review your design for unconnected parts. Use the alignment and grouping tools to connect any separate components.
    • Step 2: Identify any overhangs and add support structures if necessary. Adjust the angle of parts to reduce overhangs.
    • Step 3: Check the wall thickness of your design. Adjust the size of shapes to ensure walls are at least 1.5 mm thick.
    • Step 4: Make any final adjustments to improve the functionality and aesthetics of your object.
    • Circulate the room to provide individualized assistance.
    • Help students troubleshoot specific issues in their designs.
    • Encourage students to refer back to their sketches and brainstormed ideas to guide their adjustments.
  • Encourage Precision and Creativity:
    • “Take your time to make sure everything is just right. Precision will help your object print successfully!”
    • “Feel free to add any final decorative elements to make your design unique.”
5. Preparing Files for Printing (5 minutes)
  • Explain File Preparation:
    • “Once your design is ready, we need to export it as an STL file so it can be printed.”
  • Step-by-Step Instructions:
    • Step 1: Click on “Export” in the top-right corner of TinkerCad.
    • Step 2: Select “.STL” format from the dropdown menu.
    • Step 3: Save the file to a designated folder on your computer or an external drive.
  • Reminders:
    • “Make sure to name your file clearly so we can easily find it when we print.”
    • “Double-check that your design is complete and all parts are connected before exporting.”
6. Sharing and Feedback (3 minutes)
  • Invite Students to Share:
    • “Would anyone like to show their finalized design and explain what adjustments they made to prepare it for printing?”
  • Provide Positive Feedback:
    • “Your keychain looks so sturdy with the perfectly connected parts!”
    • “Great job adding supports to your desk organizer to ensure it prints without issues!”
7. Conclusion and Preview of Next Session (2 minutes)
  • Summarize the Session:
    • “Today, you all did an amazing job finalizing your designs, making sure they’re ready for 3D printing by checking for unconnected parts, minimizing overhangs, and ensuring proper wall thickness.”
  • Preview Next Session:
    • “In our next class, we’ll prepare your designs in Cura and start the 3D printing process. Get ready to see your creations come to life!”
    • “Keep up the fantastic work! Your attention to detail today will make your prints turn out perfectly.”
Additional Notes for the Teacher
  • TinkerCad Setup:
    • Ensure all students have access to their saved designs.
    • Familiarize yourself with common design issues and their solutions in TinkerCad.
  • Visual Aids Ready:
    • Prepare slides or posters illustrating examples of common design issues and best practices for fixing them.
    • Have pre-designed models showcasing optimal design practices for reference.
  • Materials Ready:
    • Ensure students have access to brainstorming materials (paper and pencils) from the previous session.
Teacher’s Guide: Finalizing Designs for Printing in TinkerCad
Common Challenges and Solutions:
    • Solution: Guide students to use the alignment and grouping tools to connect all components properly.
    • Solution: Help students identify overhangs and add supports or adjust angles to minimize them.
  • Thin Walls:
    • Solution: Assist students in resizing shapes to ensure all walls meet the minimum thickness requirement.
Key Vocabulary
  • Overhang: Parts of a model that extend outward without support, which may require additional material to avoid collapse during printing.
  • Wall Thickness: The thickness of the outer walls of a 3D printed object, affecting its strength and durability.
  • Alignment: Positioning shapes accurately relative to each other to ensure proper functionality and aesthetics.
  • Grouping: Combining multiple shapes into a single, unified model to simplify manipulation and design.
  • Supports: Temporary structures added during the printing process to hold up overhangs or bridges.
  • Export: The process of saving a design in a specific file format for use in another application or device.
  • STL File: A file format commonly used for 3D printing that contains the 3D model data.
  • Design Check: A tool or process to verify that a 3D model is free of common issues that could affect printing.
Teacher’s Resources:
  1. Guide to TinkerCad (link to separate document)
  2. Guide to Cura (link to separate document).
  3. Getting started with M3D Enabler (link to separate document).
