Session 5: “Printing Our Functional Objects”
By the end of the session, Grade 4 students will:
- Observe the 3D Printing Process: Watch their functional object designs being printed and understand each step of the process.
- Understand Printer Operations: Learn how the 3D printer interprets G-code to build objects layer by layer.
- Identify Print Challenges: Recognize common printing challenges such as warping, stringing, and layer adhesion issues.
- Evaluate Print Quality: Assess the quality of printed objects by examining features like layer lines, surface finish, and structural integrity.
- Reflect on the Design-to-Print Workflow: Understand the importance of each stage in preparing and executing a successful 3D print.
- 3D Printed Functional Objects: Display examples of well-printed models and those with common print issues.
- Projected Images/Videos:
- 3D Printing Process: Short video clips showing the printer in action.
- Cura Slicer Interface: Screenshots highlighting key slicer settings.
- Infographics:
- Layer-by-Layer Building: Visual representation of how 3D printers construct objects.
- Common Print Issues: Diagrams showing warping, stringing, and layer separation.
- 3D Printer Setup:
- M3D Enabler 3D printer ready with student designs loaded.
- Adequate ventilation and safety barriers in place.
- Computers or Tablets:
- For monitoring print progress and troubleshooting if needed.
- Projector and Screen:
- For live demonstrations and displaying visual aids.
- Printed Models:
- Pre-print a sample object to demonstrate common issues and their fixes.
- Notebooks and Pens:
- For students to take notes during the session.
Greet the Students:
- “Good morning, everyone! Today is an exciting day—we’re going to see your designs come to life through 3D printing!”
Recap Previous Sessions:
- “Last time, you finalized your functional object designs and prepared them in Cura. Who remembers some of the key settings we adjusted?”
Introduce Today’s Goals:
- “Today, we’ll watch our designs being printed, understand how the printer builds them, and learn about the challenges that can happen during printing.”
2. Understanding the 3D Printing Process (10 minutes)
Explain the Printing Workflow:
- “Let’s go over how a 3D printer works. When we start a print, the printer reads the G-code file, which tells it exactly how to build the object, layer by layer.”
- Visual Aid: Show an infographic of layer-by-layer construction.
- “Imagine building a model by stacking thin slices on top of each other. That’s exactly how a 3D printer creates your design.”
Demonstrate with a Video:
- Play a short video clip showing the printer in action, highlighting the layer deposition.
3. Preparing for the Print (10 minutes)
Final Design Checks:
- “Before we start printing, let’s quickly review our designs to ensure everything is set correctly.”
Review Key Points:
- Size and Dimensions: Ensure models fit within the printer’s build volume.
- Overhangs and Supports: Confirm that any overhangs have appropriate supports.
- Wall Thickness: Verify that all walls meet the minimum thickness requirements.
Encourage Questions:
- “Does anyone have any last-minute adjustments or questions before we begin printing?”
4. Live Printing Demonstration (25 minutes)
Start the Print:
- “We’re now ready to start printing your functional objects. Let’s begin!”
Monitor the Print:
- Display the printer’s progress on the projector so all students can observe.
Explain Each Step:
- Initial Layers:
- “The printer starts by laying down the first layer, ensuring it sticks well to the build plate.”
- Building Up Layers:
- “As it continues, the printer adds each subsequent layer, building your object from the bottom up.”
- Cooling and Solidifying:
- “After each layer is printed, it cools and solidifies before the next layer is added.”
- Initial Layers:
Discuss Common Challenges:
- Warping:
- “Sometimes, prints can warp if the base cools too quickly. Using a heated bed helps prevent this.”
- Stringing:
- “Stringing happens when the printer leaves tiny strands of filament between parts. Proper retraction settings can reduce this.”
- Layer Adhesion:
- “If layers don’t stick well, the print can become weak. Ensuring the right temperature and speed settings helps maintain strong adhesion.”
- Warping:
Encourage Observation:
- “Take notes on how the printer moves and any issues you notice during the process.”
5. Post-Print Evaluation (7 minutes)
Examine the Printed Objects:
- “Now that the prints are complete, let’s take a closer look at our functional objects.”
Assessment Points:
- Layer Lines: “Can you see the lines where each layer was printed?”
- Surface Quality: “Is the surface smooth or rough?”
- Strength and Durability: “Do the parts feel sturdy?”
- Functionality: “Does your object work as intended?”
Discuss Observations:
- “What did you notice about the printed objects compared to your digital designs?”
- “Were there any surprises or things you didn’t expect?”
6. Reflection and Feedback (3 minutes)
Class Discussion:
- “How did the printing process go for your designs?”
- “What challenges did you encounter, and how did you address them?”
Encourage Positive Feedback:
- “Let’s share what worked well and what we can improve for next time.”
7. Conclusion and Next Steps (5 minutes)
Summarize the Session:
- “Today, we saw our designs come to life through 3D printing. You learned how the printer builds objects layer by layer and identified some common printing challenges.”
Preview Next Session:
- “In our next class, we’ll explore how to troubleshoot print issues and refine our designs based on what we learned today.”
Closing Encouragement:
- “Great job today! Your attention to detail and creativity made your functional objects a success. Keep thinking about how you can improve your designs for even better prints!”
Additional Notes for the Teacher
3D Printer Readiness:
- Ensure the M3D Enabler 3D printer is fully operational and loaded with student designs.
- Pre-load a simple model to demonstrate common issues if time is limited.
Visual Aids Ready:
- Prepare slides or posters illustrating the layer-by-layer process and common print issues.
- Have example prints (both good and problematic) ready for comparison.
Safety Precautions:
- Ensure the printer area is safe and that students understand the importance of not touching hot parts.
- Use barriers or markings to keep students at a safe distance during printing.
- G-code: The language used by 3D printers to follow instructions for printing each layer of a model.
- Overhang: Parts of a model that extend outward without support, which may require additional material to print correctly.
- Layer Adhesion: The strength with which each printed layer bonds to the one below it.
- Warping: Distortion that occurs when different parts of a print cool at different rates, causing the model to bend or lift from the build plate.
- Retraction: The process of pulling filament back into the nozzle to prevent stringing between parts.
- Wall Thickness: The thickness of the outer walls of a 3D printed object, affecting its strength and durability.
- Infill: The internal structure of a 3D printed object, providing strength and reducing material usage.
- Supports: Temporary structures added during printing to hold up overhangs and complex geometries.
Teacher’s Resources:
- Guide to Cura (link to separate document).
- Getting started with M3D Enabler (link to separate document).
