Session 9: “Printing Complex Models”
By the end of the session, Grade 4 students will learn to:
- Finalize Advanced Designs: Ensure their complex models with moving parts are complete and print-ready.
- Understand Cura Settings: Learn how to adjust specific slicer settings in Cura to optimize prints for models with moving assemblies.
- Prepare Models for Printing: Export and import their finalized designs into Cura, setting appropriate parameters for successful printing.
- Monitor the Printing Process: Observe the printing of their complex models, noting any challenges and understanding how settings impact print quality.
- Evaluate Printed Models: Assess the quality and functionality of their printed objects, especially the moving parts.
- Demonstration Videos: Clips showing the printing of complex models with moving parts.
- Step-by-Step Guides: Screenshots or slides illustrating the process of adjusting Cura settings for advanced models.
- Example Prints: Pre-printed complex models to showcase expected outcomes and potential issues.
- Infographics: Visual representations of optimal Cura settings for different types of models.
- Computers or Tablets:
- One per student or pair, with TinkerCad designs finalized and exported as STL files.
- Cura software installed and ready to use.
- 3D Printers:
- M3D Enabler 3D printers set up and operational.
- Adequate filament available for printing complex models.
- Interactive Whiteboard or Projector:
- For live demonstrations of Cura settings and monitoring print progress.
- Printed Models:
- Examples of successful complex prints and prints with common issues for reference.
- Notebooks and Pens:
- For students to take notes on print settings and observations.
- Assistants or Volunteers:
- Additional adults to help guide students through the printing process and troubleshoot issues.
- Greet the Students:
- “Good morning, everyone! Today is a big day—we’re going to bring your complex designs to life through 3D printing.”
- Recap Previous Sessions:
- “Over the past sessions, you’ve designed objects with moving parts like hinges, pinwheels, toy cars, and gear assemblies. How are you feeling about your designs?”
- Introduce Today’s Goals:
- “Today, we’ll finalize your advanced designs, adjust Cura settings to ensure successful prints, and watch your creations come to life on the 3D printer.”
2. Finalizing Designs for Printing (10 minutes)
- Review Final Designs:
- “Before we start printing, let’s make sure your designs are complete and optimized for printing. Open your TinkerCad projects and double-check the following:”
- Connected Parts: Ensure all moving parts are properly grouped and aligned.
- Clearances: Verify that there are adequate gaps between moving components to prevent them from fusing during printing.
- Wall Thickness: Confirm that all walls meet the minimum thickness requirement of 1.5mm for durability.
- Exporting STL Files:
- “Once your design is ready, export it as an STL file.”
- Click on “Export” in the top-right corner.
- Select “.STL” format.
- Save the file to your designated folder.
3. Setting Up Cura for Complex Models (20 minutes)
- Importing STL Files into Cura:
- “Open Cura and import your STL file.”
- Click on “Open File” or use the shortcut
Ctrl + O. - Select your exported STL file.
- Adjusting Cura Settings:
- Layer Height:
- “For detailed models with moving parts, use a smaller layer height for better resolution.”
- Recommended Setting: 0.15mm
- Infill Density:
- “Ensure your model is strong enough by setting an appropriate infill density.”
- Recommended Setting: 15%
- Print Speed:
- “Slower print speeds can improve print quality, especially for intricate details.”
- Recommended Setting: 60mm/s
- Print Temperature:
- “Set the filament temperature according to the manufacturer’s recommendations.”
- Example Setting for PLA: 200°C
- Layer Height:
- Using the Preview Feature:
- “After adjusting settings, use the Preview feature to visualize how the printer will build your model layer by layer.”
- Click on “Preview” to inspect each layer.
- Ensure moving parts have adequate clearances and that supports are correctly placed.
- Final Adjustments:
- “If you notice any issues in the preview, go back and adjust the settings as needed. Ask for help if you’re unsure.”
4. Printing the Designs (20 minutes)
- Start the Print:
- “Once you’re satisfied with your Cura settings, start the print job.”
- Click on “Slice” and then “Save to File” or “Print via USB” depending on your printer setup.
- Transfer the sliced file to the 3D printer.
- Monitoring the Print:
- “While your models are printing, observe the process and note any challenges.”
- Initial Layers: Ensure proper adhesion to the build plate.
- Layer Deposition: Watch for consistent layer formation and the handling of moving parts.
- Potential Issues: Look out for warping, stringing, or layer shifting.
- Teacher and Assistant Support:
- “If you encounter any issues, let the teacher or assistant know immediately so we can troubleshoot together.”
5. Evaluating Printed Models (5 minutes)
- Examine the Prints:
- “Once your prints are complete, take a closer look at your models.”
- Layer Lines: Check for smoothness and consistency.
- Surface Finish: Assess the overall appearance and detail.
- Moving Parts: Test the functionality of hinges, wheels, and gears.
- Discussion:
- “How did your print turn out compared to your design? Were there any surprises or challenges?”
- Summarize the Session:
- “Today, you successfully finalized your complex designs, adjusted Cura settings for optimal printing, and saw your advanced creations come to life. Great job!”
- Preview Next Session:
- “In our next class, we’ll explore post-processing techniques to enhance your prints and prepare them for presentation. Get ready to add the finishing touches to your models!”
- Closing Encouragement:
- “Keep up the fantastic work! Your attention to detail and problem-solving skills are making your designs shine.”
- Cura: A slicer software used to prepare 3D models for printing by converting them into G-code instructions.
- Layer Height: The thickness of each horizontal layer in a 3D print, affecting resolution and print time.
- Infill Density: The amount of internal structure within a 3D print, impacting strength and material usage.
- Supports: Temporary structures added during printing to hold up overhangs and complex geometries.
- Retraction: The process of pulling filament back into the nozzle to prevent stringing between parts.
- Clearance: The small gap between moving parts to ensure they can move freely without sticking together.
- Grouping: Combining multiple shapes into a single, unified model to simplify manipulation and design.
- Alignment: Positioning shapes accurately relative to each other to ensure proper functionality and aesthetics.
- G-code: The language used by 3D printers to follow instructions for printing each layer of a model.
- Warping: Distortion that occurs when different parts of a print cool at different rates, causing the model to bend or lift from the build plate.
