Custom RTTL sounds
:musical_note: Your Enabler D8500 printer can now sing! Not just the usual hum, but actual monophonic melodies, just like those classic Nokia ringtones. We’ve found a way to turn the stepper motor’s noise into tunes, thanks to a solenoid’s fundamental sound-producing element. While polyphonic music is a challenge, RTTTL (monophonic tones) is now integrated into your printer’s firmware!
Introducing M37 M-code, custom-made for the Enabler D8500. You won’t find it on the standard Marlin g-codes directory.
How to use them:
M37 → Play Monophonic
It’s simpler than it sounds! Connect your printer via a serial terminal (like Pronterface) or the web terminal (http://m3d-enabler.local/)
Then, send this code:
M37 Mario:d=4,o=5,b=100:16e6,16e6,32p,8e6,16c6,8e6,8g6,8p,8g,8p,8c6,16p,8g,16p,8e,16p,8a,8b,16a#,8a,16g,
This is RTTTL – the same format used for composing ringtones on old Nokia phones. If you’re looking to compose new melodies, websites like this one can help. Just be aware that RTTTL commands can vary, and our firmware supports a specific flavor.
Beyond the terminal, you can embed M37 directly into your G-code files manually or using Orca’s printer G-code editor. For instance, add a rising tone at the end of a print by inserting this line into Orca’s end-G-code:
M37 scale_up:d=32,o=5,b=100:c,c#,d#,e,f#,g#,a#,b
