Grade 7 - Session 8: Investigating Ohm’s Law
- Develop a foundational understanding of voltage, current, and resistance.
- Measure voltage and current across a fixed resistor to verify Ohm’s Law.
- Calculate resistance at different points, observing that R remains constant for a given resistor.
- Analyze V vs. I plots to confirm the proportional relationship and understand resistance as a constant factor.
Session File:
- MeasureLab with voltage and current sensors.
- Fixed resistors (e.g., 100Ω, 220Ω).
- Breadboard and connecting wires.
- Power source (adjustable if possible).
- Laptop or PC to display live measurements.
- Worksheet for recording observations and calculations.
Introduction and Hands-On Exploration (20-25 minutes)
Engaging Students with Foundational Concepts
Introducing Voltage, Current, and Resistance
- You may start by asking:
“Have you noticed how a dim flashlight gets brighter with fresh batteries? Or how a fan speeds up when plugged into a higher power source?” - Explain:
“These behaviors are influenced by voltage (the push or pressure of electricity), current (the flow of electricity), and resistance (the opposition to the flow). Let’s break these down.”
Understanding Voltage
“Voltage is like the pressure that pushes electricity through a circuit. The higher the voltage, the stronger the push driving the current.”
Current as Flow of Electricity
“If voltage is the push, what do you think happens to the flow (current) as we increase the voltage?” - Guide students to see that higher voltage increases current flow, much like stronger water pressure increases water flow.
Resistance as an Obstacle to Flow
“What if there’s a blockage, like a pinch in a hose? How would that affect the flow of electricity?” - Explain:
“This blockage is called resistance. Higher resistance makes it harder for electricity to flow, controlling the current.”
Setting Up the Experiment to Verify Ohm’s Law
Building Simple Circuits and Setting Up Measurement Tools
- Guide students to set up a basic circuit with a single resistor, power source, and MeasureLab’s voltage and current sensors.
- You may say:
“We’ll connect a resistor and measure the voltage across it and the current through it to check if they are proportional, as described by Ohm’s Law.”
Correct Measurement of Voltage and Current
- Explain Measurement Setup:
- Voltage is measured across (in parallel with) the resistor.
- Current is measured through the circuit (in series with the resistor).
- Explain Ohm’s Law as Proportionality:
“According to Ohm’s Law, V = IR, meaning voltage across a resistor should increase proportionally with current, given a constant resistance.”
Taking Multiple Measurements by Adjusting Voltage
- You may say:
“We’ll adjust the voltage in steps, measure the current each time, and calculate R = V/I to see if resistance remains constant.” - Students will record voltage and current values at each step, then calculate R to confirm consistency.
- You may say:
Worksheet for Recording Observations
| Voltage (V) | Current (I) | Calculated Resistance (R = V/I) |
| 0 V | ||
| 1 V | ||
| 3 V | ||
| 5 V | ||
“After calculating R for each set of measurements, what pattern do you notice? Does the resistance stay the same?”
Plotting V vs. I and Confirming Ohm’s Law
- Creating the Plot and Analyzing Proportionality
- Students will plot voltage (V) against current (I) and examine the resulting line.
“What does the shape of the line tell us about the relationship between voltage and current? If it’s straight, what does that mean?” - Explain:
“A straight line shows that voltage and current are proportional. The slope of this line gives us the resistance value for the resistor.”
Reflection and Follow-Up Questions (15-20 minutes)
Verifying Ohm’s Law
“How did our results demonstrate Ohm’s Law? Did we observe that voltage and current are proportional for a fixed resistor?” - Help students conclude that the consistent resistance value R confirms Ohm’s Law.
Real-Life Applications of Resistance Control
“Why might we need to control resistance in real-world circuits? Think about devices like dimmer switches, phone chargers, or appliances that need different power levels.” - Discuss how resistors help regulate current, ensuring safe operation in various applications.
Summary and Wrap-Up (5 minutes)
Summarize Key Learnings:
- “Today, we explored voltage, current, and resistance and saw how they follow Ohm’s Law. We measured voltage and current across a resistor, confirming that they are proportional when resistance is constant.”
Real-Life Connection:
- “Understanding resistance helps engineers design safe, efficient devices that control electricity, from household lights to mobile chargers.”
- Voltage: The force that drives electricity through a circuit.
- Current: The flow of electric charge through a circuit.
- Resistance: The opposition to the flow of electric current.
- Ohm’s Law: The principle that voltage equals current times resistance, represented as V = IR .
